Plusnet Hub 2 - https non-responsive
Fixes: 253
Has anyone else seen the Hub Two go non-responsive on port 443 ... whilst Port 80 remains responsive though redirecting to https://?
Browser reports "ERR_CONNECTION_RESET" - cURL diagnostic as below...
PS C:\Users\*****> curl.exe -v https://192.168.1.254
*   Trying 192.168.1.254:443...
* schannel: disabled automatic use of client certificate
* schannel: using IP address, SNI is not supported by OS.
* ALPN: curl offers http/1.1
* Recv failure: Connection was reset
* schannel: failed to receive handshake, SSL/TLS connection failed
* closing connection #0
curl: (35) Recv failure: Connection was reset
PS C:\Users\*****> curl.exe -v http://192.168.1.254
*   Trying 192.168.1.254:80...
* Established connection to 192.168.1.254 (192.168.1.254 port 80) from 192.168.1.34 port 49789
* using HTTP/1.x
> GET / HTTP/1.1
> Host: 192.168.1.254
> User-Agent: curl/8.23.0
> Accept: */*
* Request completely sent off
* HTTP 1.0, assume close after body
< HTTP/1.0 302 Found
< Server: httpd
< Date: Mon, 23 Nov 2026 00:50:08 GMT
< Location: /forced_https.htm
< Pragma: no-cache
< Cache-Control: no-cache,no-store,must-revalidate, post-check=0,pre-check=0
< Expires: 0
< Set-Cookie: urn=1ab849c822434d04; Path=/; HttpOnly
< CONTENT-LANGUAGE: en
< X-Frame-Options: DENY
< Connection: close
* shutting down connection #0
