Authentication error when for third Party Router
kels110
Can anyone help ? just joined Plusnet a week ago and what to configure my Netgear Modem DM200 ( just as I have done for previous ISP in the past with no problem)  All settings are correct and username is xxxx@plustdsl.net and password is same as my account ( which I can log into no problem ) however keeps saying incorrect ISP username or password  ....Ive contacted tech support  and they have't really helped....anyone got any ideas or possible solutions
16 REPLIES 16
MasterOfReality
Fixes: 57
Re: Authentication error when for third Party Router
Hi @kels110
Welcome to the forums!
I assume that's a typo and you meant @plusdsl.net ?
Thanks,
MoR
kels110
Yes indeed thats what I meant and I have been entering xxxx@plusdsl.net
Fixes: 1,600
That's odd, can you post up some screenshots showing the settings you're inputting when trying to connect? (Make sure you hide any sensitive information like your username etc)
Fixes: 1,483
Moderators Note
This topic has been moved from Fibre to My Router
kels110
this is the current configuration I am using
Country: UK
ISP: PlusNet
VLANID’ value defaulted to ‘101’
Encapsulation: PPPoE
Login: Plusnet username followed by @plusdsl.net.
Account Password
Then error occurs
kels110
Previous ISP had automatic authentication enabled so this meant only unername was required and no password  and  worked perfectly !!!
Fixes: 1,600
Ah fair, thanks for the update.
Does this mean your 3rd party router is now working as you'd expect?
kels110
No it is not working as per my original post ...  keeps on saying "incorrect username or password" when I entered them correctly
EmilyD
Fixes: 117
Hi @kels110,
Thank you for confirming that and I'm sorry for any inconvenience that this is causing you.
Although you've confirmed that you've been entering the correct details, I'd recommend that you reset the account password via the reset tool here  and then try to set up the new router again. If it still won't accept the details, I'd recommend that you contact the router's manufacturer as they will be able to advise you of further troubleshooting steps.
 Emily D
kels110
Its not password issue I know my password and no need to contact the manufacturer. I simply cloned the MAC ID from the plustnet router and added it to my third party setting and it works 100%. if you Plusnet really want to help other who may encounter this issue then include this in your help tips !!!
bobpullen
Fixes: 316
Our authentication servers care nothing for the MAC address of the connecting device, so I have no idea why what you did would have helped.
It's definitely not something we need in our help tips.
kels110
Well looked around and found that solution and works 100% for me....so thanks to plusnet I use my own router which I have now configured now and and I'm not restricted by plusnet s mass produced cheap router
Mustrum
Fixes: 77
So it would be very easy to change the mac address back again and see what results you get.
There are loads of people using BT Homehubs and other routers on PN, without issue - I used a BT HH5 and a Netgear D7000 without a problem.
kels110
No need for me to experiment
