router setup using chromebook
- My Router
- router setup using chromebook
09-03-2019 5:09 PM
Hi All
looking to move my fibrebroadband account to PlusNet from vodafone. I see that I will get a new router so wanted to see if I will need to do any configuration work on it (or is it just plug and go)? I have a chromebook so it doesnt have an ethernet connection so I cant log in using a cable so would need to log in over the network. thanks
Re: router setup using chromebook
09-03-2019 5:44 PM
Hi @1jim and welcome to the forums
The router auto configures once your account goes live.
As you're thinking of fibre, it'll be a Plusnet Hub One (same as a BT Home Hub 5), the only difference is the colour - PNH1 is white and BTHH5 is black.
If you do join 'us', then before your connection goes live, it will have a default username of setup@plusdsl.net
Once it's live, providing all goes to plan, it'll revert to your username (set up, during sign up) @plusdsl.net
There are some known issues with the wifi on these hubs atm, though PN are busy sorting this out.
If you join and also have issues, pop back on here and someone will try and help you out!!
10-03-2019 7:05 AM
When you say issues with the router? Do you know what issues in particular?
We currently have a smart thermostat (Tado), a Philips hue bridge, and a Sonos bridge using wired ports. Would want those to work fine.
Additionally, using WiFi we have lg smart TV, Chromebooks, Xbox, phones, Kindle fire stick, Kindle paperwhites and Kindle fires connected wirelessly
10-03-2019 12:14 PM - edited 10-03-2019 12:17 PM
Hmm, well .....
These routers come with 2.4GHz and 5GHz wifi capabilities.
Some users have been reporting issues with the 5GHz dropping their devices (RPi, Amazon Tabs, plus other devices I can't recall, but there does appear to be a varied selection).
'Fixes' include splitting the WiFi, renaming the WiFi, Firmware updates etc etc.
Some users report that the firmware update (PN have stated that routers will be updated by the end of the 2nd week of this month) has fixed theirs whereas a few are still reporting theirs have dropped since the update.
I've personally stopped any devices from using the 5GHz and at this present time none of my devices (obviously on 2.4GHZ) suffer from dropouts.
I also, based on my own testing, believe that the hub is caching the devices, which floods the gubbins, causing it to drop the devices - another reason for thinking this is because some users simply tun their router off and back on and their devices then 'magically' reconnect.
2.4GHz is a tad slower, but reaches a further distance whereas 5GHz is faster (we're talking about how fast it goes to the router from the device, not how fast it is to the www) but doesn't reach as far.
So, you could join PN, see how it goes, turn off 5GHz if you're having issues, see how it goes, or any combo of the above and see how it goes.
Not trying to put you off, just giving my honest opinion
edit to add - from memory no devices have issues when connecting via ethernet
10-03-2019 12:36 PM
As a new fibre customer you should be sent a Hub One with the latest firmware, which has resolved this wireless problem. Having said that this isn’t a brilliant device and if you are unlucky you might get one that’s noisy when using the 5GHz channel.
What many of us have done is buy a BT Smarthub 6 off EBay for around £20 and use that instead. It has to be set up for Plusnet but this can be done over a wireless link Try the Hub One to start off and if you want better wireless or find it noisy then come back here for more advice.
10-03-2019 12:57 PM
thanks, appreciate the honesty.
seems sensible to give it a go and worst case buy another router.
last question for now (I think)- are these ok to use with a vpn? I occasionally work from home and use a vpn to connect into the network
cheers
10-03-2019 1:23 PM
From personal experience, this wasn't the case
13:49:43, 06 Dec. | ( 27.590000) System up, firmware version: 4.7.5.1.83.8.226 |
13:49:28, 06 Dec. | ( 13.090000) System start |
One day later and
01:31:28, 07 Dec. | ( 32.260000) System up, firmware version: 4.7.5.1.83.8.237.2.2 |
01:31:14, 07 Dec. | ( 18.550000) System start TR069 |
The last one I had was
16:08:52, 21 Aug. | ( 35.860000) System up, firmware version: 4.7.5.1.83.8.259 |
I could well be wrong on this too, but it's 'first in, last out' then they could still be shipping ones out with older firmware, that may or may not update a day or so later...?
Using another 'brand' of router is certainly an option as Baldrick1 suggests
I can't comment on how well they work with VPN's though if you start saying it's for work, then somebody might point out you need a business account!! But I'd wouldn't know what you're using it for
10-03-2019 1:46 PM
My experience is from a friend that upgraded to fibre last month and booted into build xxxx.263 firmware. Of course he might just of been lucky.
On VPN, I suspect it's a matter of how the particular version works. If it involves installing VPN software onto the router then the answer is going to be no go.
10-03-2019 2:04 PM
Maybe the mothership is looking after it's newest born...?
Whilst it's older kids are left to fend for themselves....!!
Or unlucky... I have read somewhere on here that a user didn't see any improvement after the update. I believe BobP is taking a closer look - trying to replicate the issue himself.
Once my router does an E.T, I may be able to see if my issues with WiFi also 'go away'...?
15-03-2019 6:01 PM
We're shipping with 4.7.5.1.83.8.259, and we have an activation event in place that will upgrade newly dispatched devices to 4.7.5.1.83.8.263 within a day or two.
We will start using 4.7.5.1.83.8.263 in manufacturing shortly but it will take some months to filter through the warehouse.
15-03-2019 6:55 PM
Darn it!!
Can't see a PNH2 anytime soon then, never mind
@1jim did you become 'one of us'?
15-03-2019 7:09 PM
If your current router is VDSL capable and you can access its settings to change login details then you can use it for PlusNet.
Settings required can be found at
https://www.plus.net/help/broadband/broadband-connection-settings/
15-03-2019 10:55 PM
Good deal via moneysavingexpert 😉
Couple of weeks till change over but it's all in progress.... Oddly Plusnet have given me one date and existing supplier a later date so time will tell I expect
15-03-2019 11:08 PM
Oh boy, what have you done!! Bunch of idiots nice people are we.
You want to keep an eye on that. PN taking over before you leave, then it should be okay, if your current one drops you too early, it could cause an issue/delay
(maybe a PN staffer can 'keep em peeled' so you have a smooth transfer....?)
- My Router
