Authentication error when for third Party Router
- My Router
- Re: Authentication error when for third Party Rout...
04-03-2019 4:08 PM
Can anyone help ? just joined Plusnet a week ago and what to configure my Netgear Modem DM200 ( just as I have done for previous ISP in the past with no problem) All settings are correct and username is xxxx@plustdsl.net and password is same as my account ( which I can log into no problem ) however keeps saying incorrect ISP username or password ....Ive contacted tech support and they have't really helped....anyone got any ideas or possible solutions
Re: Authentication error when for third Party Router
04-03-2019 4:18 PM
Hi @kels110
Welcome to the forums!
I assume that's a typo and you meant @plusdsl.net ?
Thanks,
MoR
04-03-2019 7:06 PM
Yes indeed thats what I meant and I have been entering xxxx@plusdsl.net
04-03-2019 7:33 PM
04-03-2019 7:43 PM
Moderators Note
This topic has been moved from Fibre to My Router
04-03-2019 8:12 PM
this is the current configuration I am using
Country: UK
ISP: PlusNet
VLANID’ value defaulted to ‘101’
Encapsulation: PPPoE
Login: Plusnet username followed by @plusdsl.net.
Account Password
Then error occurs
04-03-2019 8:17 PM
Previous ISP had automatic authentication enabled so this meant only unername was required and no password and worked perfectly !!!
04-03-2019 8:58 PM
04-03-2019 11:16 PM
No it is not working as per my original post ... keeps on saying "incorrect username or password" when I entered them correctly
05-03-2019 10:44 AM
Hi @kels110,
Thank you for confirming that and I'm sorry for any inconvenience that this is causing you.
Although you've confirmed that you've been entering the correct details, I'd recommend that you reset the account password via the reset tool here and then try to set up the new router again. If it still won't accept the details, I'd recommend that you contact the router's manufacturer as they will be able to advise you of further troubleshooting steps.
05-03-2019 7:29 PM
Its not password issue I know my password and no need to contact the manufacturer. I simply cloned the MAC ID from the plustnet router and added it to my third party setting and it works 100%. if you Plusnet really want to help other who may encounter this issue then include this in your help tips !!!
15-03-2019 6:40 PM
Our authentication servers care nothing for the MAC address of the connecting device, so I have no idea why what you did would have helped.
It's definitely not something we need in our help tips.
15-03-2019 8:03 PM
15-03-2019 9:43 PM
So it would be very easy to change the mac address back again and see what results you get.
There are loads of people using BT Homehubs and other routers on PN, without issue - I used a BT HH5 and a Netgear D7000 without a problem.
15-03-2019 10:01 PM
- My Router
