Asus DSL-AX82U and Nordvpn
zephyr4
I am trying to get my Asus dsl-ax82u working with Nordvpn on the router I have connected by vpn fusion and I can only download at 60mbs turn the vpn off and I get 300mbs I know its the router because I have tried nordvpn app on my android
And get a speed of 260mbs with using the app.
Does anyone know how to get it working ok so I can connect all my devices to through my router, I dont know a lot
about this topic so go easy on my.
Thanks Steve
Moderator's note by Mike (Mav): Personal information removed from a public forum.
1 REPLY 1
Fixes: 569
Re: Asus DSL-AX82U and Nordvpn
When using the VPN on the router, your speeds will be limited by the processing power of the router.  I believe the ax82 only has a dual core 1.5ghz processor and so will struggle with VPN protocols. You Android device probably has an octo-core processor running at 2ghz.
