Plusnet Router 2 Hub
IanSelwyn
Hi. I’ve just upgraded to the Router 2 Hub on a new part fibre package.
The blue light is on as an arc at the top and bottom of the router. Is this normal or should it be a full circle.
6 REPLIES 6
Fixes: 388
Re: Plusnet Router 2 Hub
@IanSelwyn Perfectly normal.
IanSelwyn
Thank you John.
I assume you cannot alter it to a full circle
Fixes: 388
No, you can't - the arcs are are totally by design.
@IanSelwyn
It is possible to turn the lights off completely if required. The light would come on if a fault is detected
Look at Hubs Home >Hub light control
@jab1
Nice to see you're back here 🙂
Fixes: 388
Only part-time, @Dan_the_Van - my 'typing arm' is non-operational.😉
RobPN
Fixes: 15
@Dan_the_Van wrote:
@jab1
OT, but +1 @jab1
