upgrade status?
squawk7000
upgrade status?
On Tuesday, giving in to sales emails and banners on My Account, I placed an upgrade order from Unlimited Fibre to Unlimited Fibre Extra.
During the order stage the forecast speeds were in the range 59-72 down and 17-18 up, with minimum guaranteed of 53.6. This ties in with the results from the BT wholesale checker, see attached.
Order completed email was sent at 00:56 am Wednesday 10th. Hence it looks like the order has gone through. Except ....
Data rate is still 39993 down and 9995 up, with a max data rate of 74466 down and 23236 up. See attached screenshot form the Hub One. This is exactly the same as before the order was placed.
Whats is happening? I have restarted the router several times with no change. The only things i can think of are:
1. You supplier is being it usual slow self and it will take longer to work through
2. The order has been completed on the Plusnet systems but not transferred to your supplier
3. There is something else which I cant see from my end
help gratefully received
Ken
4 REPLIES 4
Fixes: 1,483
Re: upgrade status?
Moderators Note
This topic has been moved from Fibre to My Orders
abails0105
Fixes: 60
Re: upgrade status?
Hi @squawk7000, thanks for getting in touch.
I do apologise for the issues you have had with your service. It looks as though our system sent out the completion early a little too early, you've got an order in place but it's not due to complete until 12/07/2019. As of tomorrow you should notice a change in speeds, please note it can take up to midnight for completion but it can often be a lot sooner.
Let us know if you need anything else
 Alice Baillie
squawk7000
Re: upgrade status?
Alice, Thanks for the update. I’ll monitor and feedback after the 12th
Ken
abails0105
Fixes: 60
Re: upgrade status?
No worries @squawk7000, if you need anything else just let us know.
 Alice Baillie
