Your Fibre Broadband is ready to go
Sarmstr7
Me again, I had an email this morning at just gone 8am from PlusNet telling me my fibre broadband is ready to go, although the only text I have about it still says by midnight on the 27th (end of today or end of tomorrow?), my router is orange power light and flashing red broadband light. I phoned and they said there might be a technical issue so has it activated and there's a problem or do I just need to wait until midnight to see what happens?
I just don't want to spend £65 because I was impatient or something
7 REPLIES 7
Fixes: 433
Re: Your Fibre Broadband is ready to go
That would normally mean by midnight today.
From your description of the lights on the router, it sounds like your connection has been made at the cabinet but the order hasnt been fully completed yet i.e there's DSL sync but no radius authentication. It should hopefully sort itself out later today...
Sarmstr7
Still not working, seems as though I may need to book a technician to come out, I hope this doesn't take too long or end up costing me money!
Sarmstr7
It's also not a promising sign that sometimes when I have been turning the router back on it gets stuck on green
Sarmstr7
Update: Spoke over the phone, they're sending an engineer tomorrow and posting a new router
Fixes: 1,605
Thanks for getting in touch @Sarmstr7
I'm sorry to see you're unable to connect to the internet following your order completing.
Can you let us know if your broadband still doesn't work after the engineer's been so we can investigate further?
Sarmstr7
Engineer has been, internet is now running fast and consistently! I can fully see now why PlusNet prides themselves on customer service - after a disaster attempting to join Vodafone with them cancelling for no reason multiple times, customer service with poor quality so you can't understand them it is such a relief to have some that understand what you're talking about, helpful and knowledgeable.
Fixes: 1,605
Thanks for the kind words @Sarmstr7 and I'm glad to see you're up and running now. Thumbs_Up
Let us know if there's anything else you'd need help with.
