Switched provider
nichollsz
Switched provider
Hi! I switched over to Plusnet from Virgin 2 weeks ago. Virgin haven't sent me a final bill and are claiming no knowledge of the switch completing (it very much has) 🤦🏻‍♀️ do I just need to be more patient or has something gone wonky somewhere?
5 REPLIES 5
Fixes: 387
Re: Switched provider
Did you use the One Touch Switching method?
nichollsz
Yes - gave Plusnet all my info
Fixes: 387
If you did use the industry standard OTS system - which still isn't clear to me - then this is another example of Virgin's inability to process such switches correctly. You will need to sort it with them.
Fixes: 585
I'd be pretty sure that Plusnet do all transfers using the OTS system
Fixes: 387
Thanks, @MisterW  - so my suspicions about Virgin are probably  correct?
