Router dispatch
scasey
Router dispatch
Hi my broadband switch from bt is due to go live by the 23rd november, can you confirm that my router will be with me before this date please.
2 REPLIES 2
SpendLessTime
Fixes: 86
Re: Router dispatch
Welcome to the forums @scasey
If you still have your BT HomeHub 5 or Smart Hub aka HomeHub 6, you can use those to connect to Plusnet.
It is normally just a change to the username and password.
The Plusnet Hub One is just a rebadged BT Home Hub 5 Type A with bespoke software.
Help for Smart Hub can be found at https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/td-p/1587673/ju...
Help for other Home Hubs can be found at https://community.plus.net/t5/My-Router/Use-a-BT-Hub-2-3-4-or-5-on-a-Plusnet-connection/td-p/1192234...
AishaK
Fixes: 12
Re: Router dispatch
Hi @scasey,
I have left a ticket on your account regarding your query. You can view this here
Should you have any further questions, please get in touch.
Thank you,
Aisha
