Router dispatch
FIXED- Subscribe to RSS Feed
- My Order
- Re: Router dispatch
20-11-2018 11:25 AM - edited 20-11-2018 11:26 AM
Hi my broadband switch from bt is due to go live by the 23rd november, can you confirm that my router will be with me before this date please.
Fixed! Go to the fix.
Re: Router dispatch
21-11-2018 11:31 AM
Welcome to the forums @scasey
If you still have your BT HomeHub 5 or Smart Hub aka HomeHub 6, you can use those to connect to Plusnet.
It is normally just a change to the username and password.
The Plusnet Hub One is just a rebadged BT Home Hub 5 Type A with bespoke software.
Help for Smart Hub can be found at https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/td-p/1587673/ju...
Help for other Home Hubs can be found at https://community.plus.net/t5/My-Router/Use-a-BT-Hub-2-3-4-or-5-on-a-Plusnet-connection/td-p/1192234...
21-11-2018 4:53 PM
