Order update?
- My Order
- Order update?
Order update?
20-11-2018 4:21 PM
I ordered a fibre broadband & landline package 2 weeks ago now and have heard nothing since, not even a confirmation email. When I log into my online account all it says is "your order is currently being processed, see below for next steps"
Could someone please let me know what is happening with my order and when my broadband & phone will change from my current supplier to plusnet?
Re: Order update?
21-11-2018 10:23 AM
Re: Order update?
21-11-2018 10:33 AM
The order was definetly 'placed' as plusnet have already taken the £200+ payment for 12 months line rental!
Re: Order update?
21-11-2018 3:44 PM
Re: Order update?
21-11-2018 5:47 PM
And please can someone explain how plusnet managed to take over £200 from my bank account if my order really 'didn't go through' like you say. (As an aside, you really need to get someone to sort that out. From browsing the forums I can see it's not just me that's had this problem!)
As someone who's leaving their current supplier because they're unhappy with the customer service, this isn't really a great start to being a plusnet customer. Especially as no one bothered to tell me there was a problem until after the 14 day cancellation period was over!
Re: Order update?
21-11-2018 5:58 PM
@Bbatty16 your problems have probably been caused by tou cancelling your current supplier, you should not have done that, unless it was Virgin. Lines on BT/Openreach can only ever have one order at a time, so if your supplier placed a cease on it, then a PN order would fail.
Re: Order update?
21-11-2018 6:04 PM
Re: Order update?
21-11-2018 6:38 PM
OFCOM introduced the Gaining Provider Led Switch process some time ago to help overcome issues when switch providers, unfortunately telling your existing supplier is the worst thing you can do and only ever adds delays and problems.
Re: Order update?
21-11-2018 6:53 PM
Hi @Bbatty16
Any agent worth their salt would make you aware of this when you call up to cancel your services - did nobody from your provider tell you this?
Our COT agents should also be checking for ceases on lines when processing sales.
If you did this online there is a chance that this might not have been picked up on - depending on the amount of time from the order to the cease.
Thanks,
MoR
Re: Order update?
21-11-2018 8:26 PM
This is exactly what seems to have happened in my "ongoing" case
