Possible to move from BT Fibre Essential to PN Fibre?
g7
My contract with BT is due for renewal shortly and I was looking at moving to Plusnet.  However when I check the broadband availability only Unlimited Broadband (est. 1Mb speed) is available and no fibre.  Is fibre to my property only available from BT?
Thanks!
12 REPLIES 12
Fixes: 334
Re: Possible to move from BT Fibre Essential to PN Fibre?
@g7 Welcome to the forums. If you post a screenshot of BT Broadband - ensuring your phone number isn't visible, we should be able to advise better.
g7
Fixes: 334
@g7 I don't know where you live, but it appears wherever it is, is in an area where Fibre To The Cabinet is unavailable as it has been converted to Fibre To The Premises only.
Unfortunately, Plusnet do not currently offer an FTTP product, so to switch to fibre, you will have to find another provider - I'm guessing here, but I suspect there may be one or more of the altnet providers available to you.
g7
Thanks for your quick response.  I'll see if there are any alternative providers.
Fixes: 334
If you can't find alternatives, BT obviously provide it.
Fixes: 89
@g7
Try the following to see who provides services to you. Look at the bottom right hand corner of the results window to see who's listed.
https://checker.ofcom.org.uk/
adam945
Fixes: 113
Hello @g7
When using the Availability Checker, are you entering your telephone number or address? It's far more accurate when using your landline number in my experience.
 Adam
 Plusnet Help Team - Leeds
Fixes: 1,491
Moderators Note
This topic has been moved from Fibre to My Order
g7
Yes, I entered my landline number.  Thanks
adam945
Fixes: 113
Thanks for your response @g7
What broadband product are you currently on with BT?
 Adam
g7
BT Fibre Essential
adam945
Fixes: 113
Cool, are you okay to send me a PM with your current landline number?
 Adam
