Plusnet is completely unprofessional
HPsauce
All Star
Fixes: 5
Re: Plusnet is completely unprofessional
@Gvu6dotcom @Uh7665uh Yes someone DID get in touch with you, but as you've changed ID it went to your previous incarnation - see above, a staff member asked for you to tell them the account, I suggest you message them ASAP! They do seem willing to help but your identity is hiding you from them.
Gvu6dotcom
I’ve still not received reply to my private message sent to member of staff. BTW how do I claim compensation for delay in service?
Gvu6dotcom
So suddenly this topic is no longer getting new replies. Anyway here is a message that I just been sent… absolute waste of time coming from Plusnet IMG_6429.jpeg
corringham
Seasoned Champion
Fixes: 23
It isn't clear to me exactly what the ECCs are for - it says "to complete the work" but doesn't say what that actually is. I would ask for a detailed breakdown of the costs (Openreach must have done a survey to get to this point so will have that info available). Since Openreach cover the fist £3400 of the costs, it suggests that the total costs are around £5400 - which should be enough for trenching over 100m of duct - overhead fibre is cheaper so would cover more distance.
Also it is strange that the VAT-exclusive and VAT-inclusive prices are the same, suggesting that it is zero rated - which I didn't think most ECCs were.
I suspect that FTTC is the only sensible choice, as full fibre at that price seems a rather expensive option!
Edit: just as a comparison, a few years ago when BT asked Openreach for a cost for Full Fibre for my premises they wouldn't even do a survey as they said the cost would obviously be >£100,000 - I now have FTTP from an altnet.
Fixes: 117
@Gvu6dotcom
You get replies on here when there's something new to talk about.
I've tagged @Tina11192  in the hope an answer as to what's happened will be forthcoming.
It appears to be there was a mistake on the OR database which should have stated a survey would be required. The results of the survey have been provided to you. You now appear to have a choice - accept the costs and get FTTP or stick with what you have.
This would apply to any ISP who uses the OR network - not just PN.
Out of interest has the Checker been updated to show non availability of FTTP.
Tina11192
Fixes: 18
Thank you for the tag @bmc , I'm sorry this has not been responded to, unfortunately I am not in the office for a few days, I'm tagging @LexLex2020 and @lahbrannan1 which should be working.
I hope this helps
Cri Ignatti
