Plusnet is completely unprofessional
Gvu6dotcom
Re: Plusnet is completely unprofessional
Thanks I do not know why user above tries to hijack my thread I will dm you my details but so far there is zero support from cs
Fixes: 117
@Gvu6dotcom
This isn't your thread - it was started by another user.
Gvu6dotcom
That other user is myself I just had to create new account as saved password did not work
Fixes: 246
Password reset?
Fixes: 117
@Gvu6dotcom
The other user merely commented you weren't alone in having problems. Users often chip in with similar problems in the hope a solution is found. That's the way the forum works.
The staff member who picked up responded to both of you in the same post.
Rhetorik2018
See my post, this has happened to me: P/net say Full fibre is available, then just with engineer coming, i rang about something and they advise me it isn't!, it is only on demand, I am now paying huge amount for month on OUC and looked again on O/Reach Postcode Finder and its says it is available, Plusnet says it still isn't.
I have asked for apology, and speak to senior manager,and been stonewalled, P/net seemed to have chnaged since last with them
Fixes: 117
Edit : Entry deleted by poster.
Gvu6dotcom
We’re not the only ones having nightmare with plusnet. I got fooled by comparison websites showing plusnet being top rated. If you check truspilot you see this… shocking IMG_6416.jpeg
Rhetorik2018
Hi, i think the C/Service thought that 'on demand' meant it wasn't in my area yet!
i have already done the P/Code checker, and yes it says it is available,plusnet is also allowing me puchase a FF package again! This is a really unprofessional state of affairs and i want to escalate it, its clearly happening to others.
Fixes: 246
There needs to be a reality check here.  See @Tina11192 ’s post.  Plusnet sell only what BT Openreach says is available.  If they offer something and it turns out to be not available, then that’s a BT Openreach issue which blights all ISPs alike.
Gvu6dotcom
This is a very poor reply from Plusnet representative. Any issue is not your fault because it’s BT? Is this a joke?
RealAleMadrid
Fixes: 68
@Gvu6dotcom  In no way did I hijack your thread, I just commented that I have had a delay on my order due to Openreach not knowing what they are doing. You don't get exclusive personal threads on a public forum.
Fixes: 246
Not a representative at all.  Just another customer with a realistic understanding of the real world.
This in no way diminishes your situation, but an understanding how things work, leads to working to a viable solution.  Pretending that things are different is futile.  You have been told that the issue has been escalated to Plusnet’s CAT and Openreach’s escalation team.
RealAleMadrid
Fixes: 68
@Townman  I think the escalations applied to my delayed order, @Uh7665uh  or @Gvu6dotcom had not been linked to any account at the time.
Gvu6dotcom
Nobody got in touch with myself since this thread was created so I do not have any reason to believe this has been escalated anywhere
