Ordered fibre extra, definitely 80/20??
Jwr
Afternoon all, I was on a 40/10 line with sky, was syncing at 3999 with real speed being 38mbps. Which for the 40/10 contract I was on was great for 2 years. I saw a good offer for plusnet unlimited fibre extra (80/20) which I ordered. Now my max line speed according to my urpn number on exchange is 46mbps clean and 45mbps impacted. Although the 80/20 product will only give me an extra few mbps ( which will be important in a busy household such as mine ) I want to be assured everything will go smoothly and I will 100% be put on the 80/20 service however marginal speed improvements will be
5 REPLIES 5
Fixes: 419
Re: Ordered fibre extra, definitely 80/20??
@Jwr  Welcome to the forum.
If the speed quoted is above 40Mbps then Plusnet will sell you the service. However I assume that there is a range of  max/min estimated speeds shown on the ADSL checker? Plusnet cannot guarantee that you will get the maximum so in reality you may gain very little.
Jwr
Thanks for the welcome, hope your safe and well, attached is the checker. I've just heard of people ordering fibre extra and getting put onto the 40/10 product. I've ordered fibre extra online as it was available for my address, switch over is 1st June. Just wanted clarity that it's the 80/20 product.
Tags (1)
Dodger21
When you are up and working go to the BT speed test site here: Click
Run the test and then a diagnostic test if you are on 80/20 you should see 20mps in the download max attainable, see attachment.
Fixes: 1,483
Moderators Note
This topic has been moved from Fibre to My Orders
Jwr
Very useful info, I'll be sure to use this once up and running. Thank-you.
