Ordered fibre extra, definitely 80/20??
FIXED- Subscribe to RSS Feed
- My Order
- Re: Ordered fibre extra, definitely 80/20??
19-05-2020 2:36 PM
Afternoon all, I was on a 40/10 line with sky, was syncing at 3999 with real speed being 38mbps. Which for the 40/10 contract I was on was great for 2 years. I saw a good offer for plusnet unlimited fibre extra (80/20) which I ordered. Now my max line speed according to my urpn number on exchange is 46mbps clean and 45mbps impacted. Although the 80/20 product will only give me an extra few mbps ( which will be important in a busy household such as mine ) I want to be assured everything will go smoothly and I will 100% be put on the 80/20 service however marginal speed improvements will be
Fixed! Go to the fix.
19-05-2020 2:57 PM
@Jwr Welcome to the forum.
If the speed quoted is above 40Mbps then Plusnet will sell you the service. However I assume that there is a range of max/min estimated speeds shown on the ADSL checker? Plusnet cannot guarantee that you will get the maximum so in reality you may gain very little.
19-05-2020 3:39 PM
Thanks for the welcome, hope your safe and well, attached is the checker. I've just heard of people ordering fibre extra and getting put onto the 40/10 product. I've ordered fibre extra online as it was available for my address, switch over is 1st June. Just wanted clarity that it's the 80/20 product.
20-05-2020 9:40 AM - edited 20-05-2020 9:41 AM
When you are up and working go to the BT speed test site here: Click
Run the test and then a diagnostic test if you are on 80/20 you should see 20mps in the download max attainable, see attachment.
20-05-2020 12:14 PM
Moderators Note
This topic has been moved from Fibre to My Orders
20-05-2020 2:11 PM
- My Order
