Full Fibre offer
Robin6
Re: Full Fibre offer
It’s about 33 feet
Robin6
Hi John,
Why am I getting offers ?
Fixes: 385
I have no idea, @Robin6
@MisterW Any thoughts?
Robin6
Finally worked it out thanks to John
Robin6
@jab1 wrote:
You won't. You need to select the 'desktop site'.
Thanks for the tip got it working now
Fixes: 117
@Robin6
Thanks for the information.
As already stated it does not appear Full Fibre is available to you. To double check login to your PN Members page and see what you're offered.
While there, check for your phone number (and then run the Checker with the phone number) and exactly what product you're on.
Finally, you could have a look and see what OpenReach say for your property www.openreach.co.uk
Fixes: 581
@jab1 BTwholesale database error / not updated yet to show fibre availability ?
but then why would Plusnet offer it if the BTW availability says no ?
@Robin6 I think this might need the wizard to see what's really going on... @Gandalf have you got a moment to have a look at this please
Robin6
attached offer I keep getting also just had a EE letter came in the post offering full fibre in my area
Fixes: 385
I have a feeling PN have dropped the ball, @MisterW , but maybe The Wizard can enlighten us?
Fixes: 117
@Robin6
There's a database problem somewhere along the line.
When you were in your Member's page did you get your phone number (you may not have a phone but there will be one associated with your account)?
It would be really interesting to see what the Phone version of the Checker returns.
Fixes: 1,662
Are we offering it now? I've had a look and there's no longer an option to select FTTP in the product change tool, so I suspect the BTw checker was updated after they realised how much work had to be done.
Fixes: 117
@Gandalf
Thanks for having a look.
Surely it would still show WBC FTTP as available (as the backbone network clearly is) but have a KCI2 marker on it and a note in the narrative below the window.
If you're right then the occupant has no apportunity to change their mind.
Fixes: 385
@bmc The backbone network isn't. The only option is FTTP OD, which is a totally different animal.
Fixes: 117
@jab1
Time will tell about the backbone network.
However, in my opinion it is there. PN would not have offer Full Fibre without it. Plus I would strongly suggest that FTTP OD (a product PN don't offer) would cost far more than £900 ECC.
Fixes: 385
@bmc wrote:
@jab1
Why do you think it is there? Genuine question.
