Order cancelled by openreach
pasc
I moved 2 weeks ago and I am still without broadband. I placed my order with PlusNet well ahead of the move to make sure I would be connected as soon as I moved in. The order is being by openreach due to reason "address not copper served", which is false as the previous occupants were with plusnet. I have the feeling plusnet doesnt do much to help: they place an order with openreach, it gets rejected, they put everything on hold for 3-4 days, then repeat. I cannot see how this will be solved if nobody put some pressure on openreach 😞
In your experience, would I be more lucky if I try BT? Surely they have more power to get openreach to actually do something to solve this (non-existing) issue?
I am WFH and this is getting very problematic.
19 REPLIES 19
Fixes: 384
Re: Order cancelled by openreach
@pasc Please post the full result off this link: https://www.broadbandchecker.btwholesale.com/#/ADSL/AddressHome , including the narrative below the matrix, but obscuring your address as an attachment to your reply.
it would make no difference if you asked BT.
markhawkin
Champion
Fixes: 22
BT have no more leverage over Openreach than Plusnet (both BT owned companies).
It sounds to me like an address issue (one location, mutiple addresses on the system).
Try your address in the BT checker and see if you get multiple entries
pasc
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Handback
Threshold(Mbps)
WBC FTTC Availability WBC SOGEA Availability
High Low High Low
VDSL Range A (Clean) help 73.4 51.1 17.9 11.2 44.3 Available Available
VDSL Range B (Impacted) help 71.7 48.1 17.5 10.2 40 Available Available
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Availability Date FTTP Install Process
WBC FTTP Up to 1000 Up to 220 -- Planned -- --
Other Offerings Availability Date
VDSL Multicast Available
Exchange Product Restrictions Status
FTTP Priority Exchange N
WLR Withdrawal Y
SOADSL Restriction N
Our records show the following FTTP network service information for these premises:-Single Dwelling Unit Residential UG Feed with no anticipated issues.
FTTP is in Planned status. An order may be placed which will be processed when the network is ready.
The exchange is not in a current fibre priority programme
As a WLR withdrawal exchange, product restrictions apply
SOADSL is not restricted at the exchange
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
For all SOADSL services,the stable line rate will be determined during the first 10 days of service usage.
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service
ADSL, ADSL2+ and SOADSL availability: If shown at FTTP or SOGEA premises,ADSL, ADSL2+ and SOADSL are not available to order due to WLR Withdrawal stop sell rules. CPs should order FTTP or SOGEA. Copper products are only available by exception.
Thank you for your interest
Fixes: 384
i would go back to PN  and ask them to request an ORDI check - that clearly shows your address can get either FTTC, or FTTP (in the near future).
Fixes: 384
@Gandalf - Another one for your magical powers?
I'm sort of wondering what Availability "PLANNED" means
Fixes: 580
There's something else not quite right with that availability ...it shows FTTC 'available' , it isnt ! It would normally show 'Exception' ?
Fixes: 384
Looking at that data, @Dan_the_Van , I would hazard a guess that FTTP installation plans are well advanced - they (OR), have obviously carried out some checks - note the comments re UG feed, no anticipated problems.
Fixes: 384
If it is not a FTTP Priority area, @MisterW ?
Fixes: 580
@jab1 irrelevant, its subject to WLR withdrawal. SoGEA is available but FTTC cant be as it includes WLR
Fixes: 384
But FTTP is not available - yet - so what does the customer do - use wet string 😁 , @MisterW
EDIT - sorry, I missed that glaring error
Fixes: 580
Removed
pasc
My order was for fttc, not fttp, so it should have gone through, right?
Fixes: 384
@pasc - correct. Let's see if @Gandalf  comes up with anything.
