Free Router?
cbcadmin
Free Router?
Do Plusnet include a free router with their fibre products?
I ask because I saw somewhere that "if you choose one". I don't recall being asked about this, but then again the order page kept crashing! Sad
Keef- Sheerness Kent UK - Vodafone FTTP via THG3000 & Three via ZTE MF286D
Previously - NowTV, John Lewis, Shell Energy, Plusnet, Sky, EE, New Call Telecom/Fuelbroadband, Virgin/NTL/Bell Cable, Crosswinds, IC24, FreeOnlineNet, X-Stream, Totalise, Freeserve, Force9, TescoNet, AOL, Freenetname, Pipex, E7
21 REPLIES 21
Fixes: 380
Re: Free Router?
I'd try using a better connection. AIUI, there is the option to select a PN Hub2 on placing the order, but it is not mandatory to use one - if you already have your own fibre-capable kit, then you are free to use that.
bobpullen
Fixes: 330
Re: Free Router?
You have to go out of your way not to select a router from memory i.e. remove it from your 'basket'. If you didn't, then I'd say it's fairly safe to say you will get sent one.
cbcadmin
Re: Free Router?
Thank you. I wish I could remember where it said you need to request one.
cbcadmin
Re: Free Router?
LOL. For once it was nothing to do with the quality of the connection. According to online chat it is a known problem. Sad But I *do* hope to have a better service going back to Plusnet. ;) Is the wifi side of a Plusnet router better than the one on the Vodafone one?
Fixes: 380
Re: Free Router?
@cbcadmin wrote: Is the wifi side of a Plusnet router better than the one on the Vodafone one?
How the blazes do you expect me to know - I have never used whatever Vodafone supplied you with - or the Plusnet Hubs, come to that, but in any case Wi-Fi performance of any router is dependent on on many variable factors.
Mustrum
Fixes: 81
Re: Free Router?
@cbcadmin  WiFi inside your property is for you to sort, not the isp.
cbcadmin
Re: Free Router?
THG3000 as per my signature. As this is a forum I was asking generally not expecting you to know, but surprised you don't have any experience of the Plusnet hub, given you are on here with over 14k posts! John.
cbcadmin
Re: Free Router?
I was asking for information not asking for Plusnet to sort anything.
Fixes: 146
Re: Free Router?
If it helps my wireless analyser shows the following for the Hub Two
Min Rate 2.4GHz 7.2Mbps, 5GHz 32.5Mbps
Max Rate 2.4GHz 216Mbps, 5GHz 1730Mbps
More details here https://www.plus.net/help/broadband/router-information/
Fixes: 380
Re: Free Router?
As this is a PLUSNET forum, only those who may have used the modem/router you mention would have been able to offer a comparison.
As I said, I have never used the Plusnet Hubs. When I joined, the only option connection-wise was ADSL, which suited my modest needs and I initially used my own Netgear DG934G modem/router, only switching to PN's TG582N when that kit began to die on me.
I was always on ADSL with PN, so had no need for a VDSL-capable Hub.
cbcadmin
Re: Free Router?
Man thanks.
cbcadmin
Re: Free Router?
I wish I could go back to ADSL. Unfortunately no one offers that in my area any more. Sad
Fixes: 380
Re: Free Router?
No-one will. ADSL, along with FTTC is being replaced (by OpenReach) with FTTP, s that is what you will get.
cbcadmin
Re: Free Router?
So I understand. Doesn't make it right though.
