FFTP Installation problems with flat roof!!
Fixes: 118
Re: FFTP Installation problems with flat roof!!
@Golfman
Good to hear things went well.
Can you post  a picture of the intenal CSP box and ONT? Thanks
Golfman
I have attached a pic of the internal boxes. The small rectangular box in corner is the splice box instead of the larger one they normaly put on outside.
Fixes: 118
@Golfman
Thanks for the picture.
Can you confirm the fibre cable comes in behind the rectangular grey box.
Golfman
Yes. Straight through the wall into the small rectangular box which is a spliced joint , used a handheld tool/machine to do the splice. Wall holes also sealed up.
