Engineer booked but already have FTTP installed
Re: Engineer booked but already have FTTP installed
Do you have a landline phone service with Sky?
As unless you are going for a VoIP service with a VoIP provider the landline number will be lost when you transfer to plusnet.
markhawkin
Champion
Fixes: 22
@steway_
There is a long list of providers who can use a CityFibre connections. It's more or less any significant ISP (except the BT group companies).
If a "value" supplier is preferred then Vodafone is the obvious one to look at (they also do "landlines" should that be needed).
A less "big name" to consider for broadband only might be YouFibre.
Fixes: 479
@markhawkin wrote:
@steway_
More expensive but highly regarded is Zen https://www.zen.co.uk/cityfibre/
