Can I specify a particular date to start contract
CornishLass
My contract with my present supplier ends on the 16 August.   When is the best time to put my Plusnet order in .   I don't want Plusnet starting before the 16th August otherwise I'd be up for terminating too early with extra costs.  (I'm already connected to Full Fibre so its just a change of supplier)  Thanks.
11 REPLIES 11
Fixes: 580
Re: Can I specify a particular date to start contract
@CornishLass
Is your Full fibre connection an Openreach one ?
CornishLass
Oh crumbs.  You have me there.  I changed to Sky and they put the Full Fibre connection in. I know they connected from the street into the house
Fixes: 580
@CornishLass Ok, well Sky do normally use Openreach ?
Does the ONT (little white box into which your router is plugged) they installed have an Openreach logo on it ?
The reason for asking if the existing service is an Openreach one, is that if it is then the transfer to Plusnet is simple. There's no engineer visit required, everything can be done remotely and the transfer completed in a couple of days
CornishLass
Thank you for your replies.  The little white box does have an OpenReach logo on it
Fixes: 580
Thanks for checking. In that case transferring to Plusnet should be simple and should only take 24-48hrs.
You should be able to specify a start date when you sign up although it's a while since I signed up and so aren't familiar with the latest process.
I'd aim to get your transfer date a day or two before before your current contract expires, that way you won't go onto any expensive out-of-contract rate with Sky. You pay monthly in advance so you will have already paid Sky to the end of the contract. Leaving before the end date just means any refund is slightly reduced
Probably best to give Plusnet sales a call and check if you can specify a start date but since your contract doesnt end for a month then it's not too urgent
Fixes: 383
@CornishLass , in that case, the switchover would be a remote one completed in 2-3 days, as @MisterW  says.
CornishLass
Thank you for your help
rowanfletcher
Yes, you can choose a preferred activation date when placing your order. Since your current contract ends on 16 August, it's a good idea to place your Plusnet order around 2–3 weeks beforehand and request an activation date of 16 August or later. That gives Plusnet enough time to process the switch while helping you avoid early termination charges. If possible, double-check with Plusnet when ordering to make sure the requested activation date is noted.
Fixes: 383
with respect, @rowanfletcher , you clearly haven't read/understood posts made on this topic.
CornishLass
Just to update you.  I've signed up and got a start date all sorted.   Thanks for all your help.
CornishLass
I’m here on Plusnet.  Connected today. Easy peasy.  Got the message. Plugged the router in and sat down on the floor thinking it was going to be a longer job. Next thing the router turned blue. Connected iPhone iPad Alexa Octopus Mini Mac. Job done. Did receive a weird message saying I wasn’t connected correctly but it was all working. Double checked connections. All in correctly. Didn’t think it would be that straight forward🥳
