Plusnet Are you able to provide FTTC?
- My Account/Billing
- Re: Plusnet Are you able to provide FTTC?
- « Previous
- 1
- 2
- Next »
30-05-2013 9:34 AM
This contradicts what you just said - activating at the exchange without a physical connection is rather useless
Quote from: JamieDanjoux Well plusnet said that they'd have to install the phone line but there is one already there and just the case of needing to be activated at the exchange.
Message 16 of 19
(270 Views)
30-05-2013 11:24 AM
Quote from: JamieDanjoux It is a new build house, and obviously it is a new install!!
Right, with you. We can place an order for the phone line but from the information you've given it would need to be a new install as we don't have a phone number - that means an engineer will attend to install the socket (as far as I'm aware) so you could show him the wiring and see what he says.
Unfortunately though we'll not be able to provide fibre until we have a line to check against, that in mind it'd probably be worth ordering ADSL and upgrading if fibre does turn out to be available - your call on that one really.
Message 17 of 19
(270 Views)
30-05-2013 11:39 AM
What I meant oldJim was that the actual phisical wire is there. But it's not attached to anything at my end.
Sorry for confusion. There is no line on that wire as a line needs to be installed and activated by a BT engineer.
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
Message 18 of 19
(270 Views)
31-05-2013 10:28 AM
Message 19 of 19
(270 Views)
- « Previous
- 1
- 2
- Next »
