Missed direct debit and can't get on plus net website
- My Account/Billing
- Re: Missed direct debit and can't get on plus net ...
06-12-2019 6:20 PM
Help please!
Re: Missed direct debit and can't get on plus net website
08-12-2019 10:48 AM
Hi @robmeadows
We're sorry to hear that you have had difficulty making payment. On checking your account it appears to have been cleared.
If you are experiencing issues with paying your bill on time, the workaround for this and to stop the need for the two weeks grace is to change your invoice date.
You can change your billing date by logging into the Plusnet website https://www.plus.net/member-centre/login
Once you're in click 'bills and payments' and 'change bill date', this will present you with a calendar to choose your new date It's worth noting that the 1st of each month is not possible to select as a billing date, the earliest you 'll be able to choose is the 2nd.
Please be aware this is an invoice date change and the direct debit will come out around 5 working days after.
You are only able to change your billing date once every 4 months.
Kind Regards
