Extra usage allowance unfair charge?
- My Account/Billing
- Re: Extra usage allowance unfair charge?
26-09-2010 9:18 AM
I had actually gone over by 0.01GB, so it seems a bit extreme to charge me for another GB when the charging period was up anyway.
26-09-2010 9:24 AM
What package are you on? as extra Gb is now in 5 Gb blocks and cost a lot more
26-09-2010 9:35 AM
29-09-2010 2:33 PM
If you pay in advance your charge is 1.00 per gig but 1.25 as extra usage. If you don't want to go over a certain limit then you can set that limit by visiting the manage my usage part of your account.
Jojo
01-10-2010 7:47 AM
I am complaining about the timing, I thought that was obvious from my message.
01-10-2010 8:36 AM
01-10-2010 10:11 AM
04-10-2010 10:56 PM
Please can some one explain
When Plusnet charges you Extra £5.00 for extra 5GB nearly at the end of month if exceeding your limit.
Is the unused balance of 5gb purchased for the month carried forward into the next month?
Thanks in advance.
04-10-2010 11:35 PM
If you are approaching your limit close to your billing date you might want to set an appropriate maximum spend in Manage My Usage. If you reach the limit you set your speed will be restricted to 128kbps until reset on billing day.
12-10-2010 10:18 PM
So I hit my 15GB limit (on BBYW 2) and am restricted to 128k till my month's up on Friday (from when I've upgraded to the new 60GB package).
Can I buy extras to get me back on full speed till then? I have set a maximum extra but it's being very slow to kick in if it's working. Or is BBYW2 set up such that it can't go over?
Any advice gratefully received
TP
12-10-2010 11:09 PM
13-10-2010 7:04 PM
But isn't that a "change of product".. presumably kicking in on the next billing date? (And worse.. overwriting the change I've already made to a new product for next month?)
I changed this one to say I was willing to spend an extra £3.. but nothing happened.
https://portal.plus.net/data_transfer_watch/
13-10-2010 9:18 PM
13-10-2010 9:36 PM
