Ditching the call plan revisited
cpcnw
Following on from Townman's suggestion here
https://community.plus.net/t5/Broadband/Ditching-the-Call-Plan/m-p/1989337
I have attached my recent bill - which I don't quite understand?
If I get rid of Plusnet Anytime I save £12.02 - even if I don't port my number [£1.44pcm] that brings the bill down to £26.40
What I am not getting is how the 'Line Rental' is £30.46 but Unlimited Fibre is removed?
From what I understand I *have* to pay 'Line Rental' regardless because it's not possible to provide anything without that component anyway?
So there is no way to get my bill down lower than removing the Anytime call plan?
5 REPLIES 5
Fixes: 1,491
Re: Ditching the call plan revisited
Moderators Note
This topic has been moved from Broadband to My Account / Billing
Fixes: 466
In a word, no.
Line Rental is a charge for the connection to your property, be it used for your phone service (over the Internet or PSTN), your Internet connection, or both.
cpcnw
No to what? You saying I can get rid of the line rental but keep fftc internet?
cpcnw
Ah OK you are saying "No, you can't reduce your bill any further"
Confirming my assertion.
Thanks!
Fixes: 466
@cpcnw
 Sorry for the double negative. The correct answer to your question is yes, there’s no way to reduce your bill any further.
Your assumption is correct.
