Change package
Charliecat
Change package
Can i change from Unlimited Fibre  to Unlimited Fibre Extra before my contract ends in April 2021
9 REPLIES 9
Jonpe
Fixes: 9
Re: Change package
I doubt PN will have any objection to you upgrading to a more expensive product.  However, they might require you to enter into another contract, i.e. one that expires later than your current one.
Try posting under My Account/Billing and a member of PN staff will probably respond quite quickly (they tend not to spend much time in General Chat).
Strat
Fixes: 565
Re: Change package
Moderators Note
This topic has been moved from General Chat to Accounts / Billing.
Charliecat
Re: Change package
Thanks for moving it was about to it myself.
Mustrum
Fixes: 77
Re: Change package
Before anyone can answer that question, is your line capable - enter your phone number in the DSL checker:
Post the results, make sure you hide your phone number.
Charliecat
Re: Change package
How do I post the results and hide my phone number?
Alex
Fixes: 13
Re: Change package
Just copy and paste what it says on a reply, and just take out your phone number.
If it is an image, then any basic paint package you have, you can put a black square over it for example.
I don't think CS will need your number, as they'll be able to lookup your account if you give them your username.
Charliecat
Re: Change package
Alex
Fixes: 13
Re: Change package
Looks like it, you haven't posted any personal information there.
RealAleMadrid
Aspiring Hero
Fixes: 59
Re: Change package
@Charliecat  Your estimates are below 40Mbps so you will not get any increase in speed by going for Fibre Extra. It only improves your speed if you are already at full 40Mbps sync speed on the 40/10 fibre package. Your maximum observed speed is only around 27Mbps so a fair bit below your estimate of around 35Mbps. You need to investigate why you are not getting the expected speed, have you tried connecting to the test socket behind the master faceplate, that would check if your internal phone wiring is reducing the speed?
