Change of package
Dev
Change of package
I have changed my package from Fibre extra to Fibre  (no landline). New package went live on 23 Aug. However this is not reflected in my online account as it still shows the old package and costs. Can this be looked into? Thanks a lot.
4 REPLIES 4
willcutforth
Fixes: 113
Re: Change of package
Hey there @Dev it's showing ok from our side. Has it changed at all or not? If not, I can find out how to fix it.
 Will Cutforth
Dev
Thanks a lot. Staff has opened a question on my account.
willcutforth
Fixes: 113
I think @Gandalf is the one to thank even though he is hiding. He messaged me to tell me he was on the case.
 Will Cutforth
Fixes: 1,638
It was I. There was a discrepancy in our systems I raised and has been fixed.
