Cap on call charges
- My Account/Billing
- Re: Cap on call charges
Cap on call charges
01-09-2014 7:13 PM
Is it possible to invoke a cap on call charges each month.
Message 1 of 7
(1,558 Views)
6 REPLIES 6
01-09-2014 7:59 PM
Not really
You can set the credit limit but if it is exceeded then the line is blocked and there is a charge to unblock it http://www.plus.net/support/phone/credit-limit-and-top-ups-guide.shtml
You can increase the credit limit via the portal but can only reduce it by raising a ticket
Quote 3. What happens if I use my credit before the end of the month?
As you approach your credit limit, we'll email you to make sure you know that you're getting close.
If you reach or go over your credit limit, your calls (apart from emergency and operator) will be redirected to our Support Team and a charge of £5.76 will be added to your next bill.
You'll need to top-up and have at least £5 credit available before you can make calls again.
Message 2 of 7
(703 Views)
01-09-2014 10:31 PM
Anytime calls cost £5 per month, adding 300 minutes of international calls costs £2 per month and you can buy 100 minutes to mobiles at £3 per month. That does not cover every possibility and you could exceed your international or mobile allowance but for many practical purposes these could limit your call charges.
Message 3 of 7
(703 Views)
01-09-2014 10:44 PM
unless someone in the property phones premium rate numbers including the directory enquiry scams (all of them)
Message 4 of 7
(703 Views)
02-09-2014 12:02 AM
Unfortunately Plusnet do not know what your call charges are until BT Wholesale update them (daily I think) so any cap at CP level (Plusnet) would not be effective against high charges run up during one day.
Call me 'w23'
Message 5 of 7
(703 Views)
02-09-2014 7:11 AM
I believe it is technically possible to bar outgoing calls to premium rate numbers http://www.openreach.co.uk/orpg/home/updates/briefings/downloads/wlr01811.pdf . I understand that BT offer this service for a monthly fee but I don't know if Plusnet do likewise.
Message 6 of 7
(704 Views)
02-09-2014 2:46 PM
Hi corsa57,
Unfortunately outbound call barring isn't a feature that we offer nor is barring calls to premium rate numbers.
Sorry if this causes any inconvenience
I will certainly make the recommendation for this to be considered for the future, however, there are no guarantees that the suggestion will be put into practice though
Message 7 of 7
(704 Views)
