Can't log into my account
Noor-Isolde
Hi, I've been trying to log into my account in the member centre but it wont let me, I know my username and password are right so I don't understand whats happening. Any advice/help would be greatly appreciated.
Tags (1)
9 REPLIES 9
Fixes: 1,601
Re: Can't log into my account
Sorry to hear you're having problems logging into your account.
Do you experience the same problem using a different web browser to what you normally use?
Noor-Isolde
Yes the same thing happens when I use google chrome or firefox.
Fixes: 1,601
That's odd, is the username you're using the one you've provided in your forum profile?
Noor-Isolde
fxxxx@xxxxxx.plus.com
Moderator's note by Adie (Dvorak) obfuscated the email address
Fixes: 1,601
You wouldn't login to your account using your full email address.
Any emails we've sent you should have your username at the top.
(P.S. I'd recommend editing your post to remove your email from a public forum)
Noor-Isolde
Well then I have forgotten my User name. Which means I can't log in to get it.
adamwalker
Fixes: 221
I think a phone call would be the quickest way to get the username to you following a few account security checks.
I've just tried calling but no one picked up. Please let me know if there's a good time for me to call you before 7.30pm today.
 Adam Walker
Noor-Isolde
I'm not home until about 6pm. Any time after that should be fine.
adamwalker
Fixes: 221
OK, no problem. I'll speak to you later Smiley - Adam
 Adam Walker
