Can I change my username
- My Account/Billing
- Can I change my username
30-06-2010 3:51 PM
Re: Can I change my username
30-06-2010 4:29 PM
One of the Digital Care Team will advise on the current situation.
30-06-2010 4:53 PM
If it is just for the purpose of email I would suggest that a solution would be to purchase a domain name (not very expensive) and then your username is known to nobody but yourself and PN.
I wasn't keen on my email address and now have my own domain which is much better, particularly as it is less long-winded.
30-06-2010 5:26 PM
Quote from: poppy If it is just for the purpose of email I would suggest that a solution would be to purchase a domain name (not very expensive) and then your username is known to nobody but yourself and PN.
That's actually the reason why I want to change my username as I have a domain which I was previously only using for email however I now wish to use it for a blog that I want to run from my home pc and therefore because my ip address will be linked to my account then it will identify me if anyone does an ip search. That is correct isn't it?
30-06-2010 5:29 PM
If that's the case, we can change that for you so it reads something along the lines of ipaddress.plus.com, if you'd like us to do that just visit the help assistant, raise a question and ask us to change the reverse DNS to your IP address.
30-06-2010 6:15 PM
jim:quote
30-06-2010 6:36 PM
I had the same thing a few years ago - happily, it was changed quite quickly by PN.
30-06-2010 6:46 PM
01-07-2010 2:19 PM
01-07-2010 3:21 PM
02-07-2010 8:09 PM
13-07-2010 1:35 PM
13-07-2010 3:00 PM
As it is going to be a blog I treat it much the same way as I would any forum by wanting to hide behind an air of anonymonity
I take it I just raise a ticket.
dick:quote
13-07-2010 3:06 PM
Quote from: andun84 I take it I just raise a ticket.
We'll get this sorted for you, you'll see the ticket on your account shortly.
13-07-2010 4:08 PM
I have two domains and they both give my name though not address.
I thought that with my Plusnet one I had opted out of having name and address displayed.
Can this not be done?
