Bills
Toynet
Bills
Hi
Please could I have some copies of my bills for Nov 2023, Dec 2023, Jan 2024, Mar 2024 and April 2024. I have previously had a spreadsheet of the information sent to me as the physical bills were not available.
Thank you
9 REPLIES 9
lahbrannan1
Fixes: 4
Re: Bills
Hi @Toynet
You should be able to access your historical bills via the online member centre. Are you able to access this or are you having issues?
For reference, the link is below:
Login | Member Centre | Plusnet
Many Thanks
Lee
Lee Brannan
Fixes: 585
Re: Bills
@lahbrannan1  billing history will only go back so far, currently to Jun 24. I think @Toynet is asking for information on bills prior to that. AFAIK that's not available.
Marsh
Fixes: 41
Re: Bills
Hey @MisterW
You are correct. Any bills before that date, it is not possible for us to get even on our end.
Josh
Re: Bills
Having had a look at mine it appears that the previous 15 monthly bills are available for download using the customer-facing web interface. Which is why I *never* go paperless. You never know when you are going to need bills older than the past 15 months.
Re: Bills
Perhaps you are going to have to start mailing out either the .PDFs as attachments (rather than a weblink) or have facilities for paper bills? There are perfectly valid requirements to have access to such data/billing (IMO).
Fixes: 387
Re: Bills
When I was with PN, i used to download my invoice as soon as I was advised it was available (as a PDF) so  I had it available if I needed it.
Re: Bills
Indeed. I think our working practiices may be broadly aligned on this,
Opinion.
It is not inconceivable that people may think the weblink in the e-mail received from a provider of a service may be persistent and therefore the document could be downloaded at a future date. Nothing ever disappears on the web? Does it? Apparently it can.
RadioFox
Re: Bills
@jab1 Me too. In fact all of my utility bills (gas, electric, water, etc.). Also payslips, P60's. Always worth keeping on your own local drive.
Fixes: 387
Re: Bills
Great minds, @RadioFox . 😉
