BT Sport Cancellation
hayd100
Hi, Could I have help to cancel BT Sport from my plusnet account please.
6 REPLIES 6
willcutforth
Fixes: 113
Re: BT Sport Cancellation
Hey there @hayd100 and welcome to the forum!
I have created a ticket on https://www.plus.net/wizard/?p=view_question&id=232400501 to get it removed for you. Please reply and I will get it sorted. Smiley
 Will Cutforth
annajones24
Hi. I would also like to cancel BT sport. Thank you
ClaudiaG23
Fixes: 25
@hayd100 and @annajones24  You both can cancel your BT Sport on the Member Centre. This is under the "Add-ons" tab along the top once you've logged in. Smiley
 Claudia Garner
RealAleMadrid
Fixes: 67
@ClaudiaG23  I don't believe that is correct, you can add BT Sport but not remove it in the member centre, there are loads of posts on the forum asking for BT sport to be removed.
SammyM
Fixes: 101
Yeah my bad @RealAleMadrid  I did tell her that and realised after my mistake Sad
I will blame it on my brain and the caffeine Cheesy
 Sammy M - Sheffield Team
ClaudiaG23
Fixes: 25
@annajones24 I've sent you a ticket from your account. You can view this here https://www.plus.net/wizard/?p=view_question&id=233600685. Please can you reply to the ticket and then I can get this removed for you.
@hayd100  I can see you have been in touch and had your queries sorted is that the case?
 Claudia Garner
