BT Sport Cancellation
- My Account/Billing
- Re: BT Sport Cancellation
15-03-2023 2:31 PM
Hi, Could I have help to cancel BT Sport from my plusnet account please.
15-03-2023 4:01 PM
Hey there @hayd100 and welcome to the forum!
I have created a ticket on https://www.plus.net/wizard/?p=view_question&id=232400501 to get it removed for you. Please reply and I will get it sorted. ![]()
03-05-2023 9:43 PM
Hi. I would also like to cancel BT sport. Thank you
04-05-2023 9:57 AM
@hayd100 and @annajones24 You both can cancel your BT Sport on the Member Centre. This is under the "Add-ons" tab along the top once you've logged in. ![]()
04-05-2023 10:00 AM
@ClaudiaG23 I don't believe that is correct, you can add BT Sport but not remove it in the member centre, there are loads of posts on the forum asking for BT sport to be removed.
04-05-2023 10:10 AM
Yeah my bad @RealAleMadrid I did tell her that and realised after my mistake ![]()
I will blame it on my brain and the caffeine ![]()
04-05-2023 10:46 AM
@annajones24 I've sent you a ticket from your account. You can view this here https://www.plus.net/wizard/?p=view_question&id=233600685. Please can you reply to the ticket and then I can get this removed for you.
@hayd100 I can see you have been in touch and had your queries sorted is that the case?
