IPv6 Trial Tests and Feedback
- Trials
- IPv6 Trial
- Re: IPv6 Trial Tests and Feedback
18-12-2013 10:12 AM
They were fine yesterday (ipv4) but today I just get a spinning wheel.
Not all though but a lot of them.
18-12-2013 10:19 AM
Quote from: SimonHobson I'd find it hard to imagine any manufacturer would default to anything but "block inbound traffic".
That is an understandable position to take, and infinitely better than a default 'allow all unsolicited traffic' but I believe there is scope for something more balanced as I touched on in this post in the IPv6 Security thread. I won't copy it here otherwise it'll derail the original topic of this thread but it essentially adopts a 'allow all unsolicited traffic except that known to be a potential threat'. Do come on over to that thread though as it'd be good to chew the fat further!
18-12-2013 10:24 AM
18-12-2013 10:28 AM
I have another issue, my speed has HALVED!
Previously
http://www.speedtest.net/my-result/3033164064
18-12-2013 10:33 AM
Quote from: Hairy I have another issue, my speed has HALVED!
Hi
These are test accounts so will likely have the wrong speed profile attached. I think that may have been mentioned in the initial trial post. If you PM Dave I'm sure he can alter it for you.
18-12-2013 10:35 AM
You can check the PN profile by logging into the member centre with the test credentials. [EDIT] I do hope it's OK to mention this.
18-12-2013 10:43 AM
Quote from: paulmh5 These are test accounts so will likely have the wrong speed profile attached. I think that may have been mentioned in the initial trial post. If you PM Dave I'm sure he can alter it for you.
Nope not mentioned on any of the current test threads.
I also can't get to some sites.
e.g forums.moneysavingexpert.com & facebook
Also my updates are failing
E.g.
Quote Err http://security.ubuntu.com/ubuntu/ saucy-security/main libqt4-test i386 4:4.8.4+dfsg-0ubuntu18.1
Connection failed [IP: 2001:67c:1360:8c01::22 80]
I also note that some icons/jpegs are not showing. Eg the cat pic on MJN's tag line.
18-12-2013 1:02 PM
Quote from: Hairy I also note that some icons/jpegs are not showing. Eg the cat pic on MJN's tag line.
Whoa... This is serious.
That image is hosted on a dual stack server thus even without IPv6 you should be able to view it over IPv4. I wonder if a previous connection failure (over IPv6) has been cached by the browser and thus it isn't 'wasting' effort trying to refetch...?
Does a brower refresh help or, better still, can you view the image (and admittedly more importantly the other sites you mentioned) with a different browser?
Out of interest, what address do you get when visiting www.newtonnet.co.uk/whatismyip ? This will indicate which protocol your browser if preferring (for my site at least). Visting ipv4.newtonnet.co.uk/whatismyip and ipv6.newtonnet.co.uk/whatismyip will force the respective protocol, with no opportunity to use the other.
18-12-2013 1:32 PM
18-12-2013 1:47 PM
I'll be trying to break IPv6 until Friday at least.
18-12-2013 2:02 PM
Quote from: MJN Does a brower refresh help or, better still, can you view the image (and admittedly more importantly the other sites you mentioned) with a different browser?
A refresh does nothing different. Chromium does the same to the ads on Samba,no access to the other sites there either. Your whatsmyip displays the ipv6 ip and the ipv4 one displays the ip4 address.
Killing my ipv6 stack allows me to access the moneysavingexpert site but not fb. (by adding net.ipv6.conf.all.disable_ipv6 = 1 to the sysctl.conf)
18-12-2013 2:09 PM
Do you have another client you can experiment with to see if the issues persist?
18-12-2013 2:12 PM
I have my lt running 24/7 or another I can test with both running LMDE
18-12-2013 2:25 PM
18-12-2013 2:29 PM
Your ip test shows the ipv6 address, your cat shows, FB still down, MSE up.
This is via wifi the pc is hard wired.
EDIT can't connect to the test sites on the lt either, apart from http://v6.testmyipv6.com/
