Akamai v6 - peering issue?
- Trials
- IPv6 Trial
- Re: Akamai v6 - peering issue?
- « Previous
- Next »
09-01-2015 12:24 PM
what settings you use to make it work?
dhcpv6 prefix mode doesnt work for me on the BNGs
09-01-2015 12:54 PM
Just Native IPv6 on PPP with Stateless Auto Config. You won't get the same prefix each time you connect so things like TBB Monitors will need to be updated.
09-01-2015 5:10 PM
AndyH, any chance you could run a tracepath6 for me?
tracepath6 www.pn-sn-test.edgesuite.net
and same for one of the akamaihd.net domains?
Im trying to get some ipv6 tests accessible over the platform, and if i have time this evening I will run a tcpdump on my local side and the edge server with various size packets. Of course, im only on a HE tunnel though.
13-01-2015 10:44 PM
Quote from: AndyH Just Native IPv6 on PPP with Stateless Auto Config. You won't get the same prefix each time you connect so things like TBB Monitors will need to be updated.
cant get this to work, how do I know what the prefix is without dhcp?
15-01-2015 9:44 AM
Just change it to this:
![](http://i.imgur.com/PxPFUET.png)
IPv6 works on all gateways with this setup for me.
- « Previous
- Next »
