intermittent dial tone
spuddyhontas
Hi, just went to make a call tonight and noticed that instead of a constant dial tone it is intermittent but constant. Wondered if this would be affecting service as everything seems to be working fine. Regards, Sarah
6 REPLIES 6
Strat
Fixes: 565
Re: intermittent dial tone
Sounds like you have a voice mail.
198kHz
Fixes: 42
It can mean various things, but the most common is that you have a message waiting.
Try dialling 1571 and see if you have a message.
BT technician (Retired)
spuddyhontas
Thanks for the speedy reply.
Was a new one on me, since I've always had an answer machine built in to my phone and didn't request the 1571 service it didn't occur to me.
Once again, thanks for solving
Sarah
198kHz
Fixes: 42
I believe it is currently the default on a new provision or migration.
You can ask for it to be removed here - https://portal.plus.net/plustalk/index.php?page=wlr_add_call_features
alanf
Quote from: Force
If that's the case then the web site needs updating
"Although Voicemail (1571) is free, you'll need to add it via the Telephone Control Panel before you can use it. "
http://portal.plus.net/support/phone/call_features.shtml
biggles001
I found that when I activated call diversion,the dial tone was intermittent,didn't happen when I was Talktalk,but it did when I was with BT many moons ago  Smiley
