Voicemail
- Home Phone
- Voicemail
Voicemail
03-11-2016 11:05 PM
Hi, I've just moved to Plusnet from another ISP with which I had caller display and dialled 1571 for messages. When my phone was connected to Plusnet a message told me that if there was a message I would hear a different tone. This has not happened. When I dial 1571 I'm told I have no messages even if the message indicator light is flashing and there is indeed a message. I don't have caller display. I'm just a bit confused! Please could someone explain the system. Thanks.
Re: Voicemail
04-11-2016 12:00 PM
Welcome to the community forums @Rosa
That is correct for how the 1571 voicemail would work.
Do you have your own answer machine? Maybe built in to the phone handset?
It's possible that your own answer machine/built in voicemail is picking the call up before the 1571 on the line has chance to.
Re: Voicemail
04-11-2016 5:52 PM
Thanks. That is what I was told too. It might be correct but it doesn't work on my phone.
Re: Voicemail
04-11-2016 6:14 PM
Thank you.
Re: Voicemail
05-11-2016 1:52 PM
