Voicemail personal greeting
- Home Phone
- Re: Voicemail personal greeting
23-10-2015 12:53 PM
I am disappointed to be told by a PlusNet agent today that Voicemail Extra Is necessary to be able to have a Voicemail personal greeting. I have looked at http://www.plus.net/support/phone/call_features.shtml#voicemail and there is a clear implication that Voicemail alone allows personal greetings. The first few lines read: "Voicemail and Voicemail Extra (1571)
Whether you're away from home or on another call, Voicemail acts like a built in answerphone to make sure you don't miss a call. With Voicemail you can:
Save messages for up to 20 days
Record your own greeting message
Standard Voicemail is included with all our phone packages, but it's not switched on as standard. To start using it, you'll need to go to the Telephone Control Panel and add it.
In addition to the standard Voicemail features, Voicemail Extra allows you to:
Choose the number of rings before a call is answered
Check your messages from any phone (PIN Protected)
Link to your mobile and get SMS alerts††when new messages are left
Save messages for up to 30 days
Identify up to 3 callers who have hung up without leaving a message (as long they have not withheld their number)
Message 1 of 5
(3,266 Views)
4 REPLIES 4
26-10-2015 9:29 AM
Message 2 of 5
(1,636 Views)
16-11-2015 10:24 AM
Thanks, Adam. I've seen those instructions before but when I dial 1571 I don't get a Main Menu. Today, when I have no messages, 1571 just tells me that I have no messages and, "Goodbye". If I press 2 when I have dialled 1571, I just get "Goodbye".
Message 3 of 5
(1,636 Views)
16-11-2015 5:16 PM
Hi pluscomm,
Thank you for your reply.
Has your handset got its own voice mail built in? If it does this could be over riding the 1571.
Message 4 of 5
(1,636 Views)
16-11-2015 5:38 PM
If a customer has their own answering machine then 1571 may well not have any messages but it won't prevent access to the 1571 menu system!
Which BT Wholesale 1571 product do PN supply as there are many variants, including the original basic one that doesn't allow the setting of a personal greeting...
Message 5 of 5
(1,636 Views)
- Home Phone
