Tree issue
- Home Phone
- Tree issue
Tree issue
02-09-2013 4:39 PM
Who's responsibility is it to trim back the trees? Thanks.
Re: Tree issue
02-09-2013 4:46 PM
I suspect in the first instance it'd be the local council, at least as far as enquiring goes. I'm not sure we'd be able to report it to Openreach unless there was actually some damage showing.
Hope that helps.
Re: Tree issue
02-09-2013 4:52 PM
Re: Tree issue
03-09-2013 8:42 AM
jim:quote
Re: Tree issue
03-09-2013 11:11 AM
Sorry if you've done that already.
Re: Tree issue
03-09-2013 11:24 AM
Re: Tree issue
03-09-2013 11:32 AM
Re: Tree issue
03-09-2013 11:49 AM
Quote After about 1/2 got through to council who said that they would arrange to Highways Agency to attend
I wonder who they'll pass it on to ?
Re: Tree issue
20-09-2013 8:44 PM
Re: Tree issue
21-09-2013 8:52 AM
Quote from: nanotm forestry commission, who will pass it on to the environment agency, who having nothing but enforcement inspectors will hum and ha about it, in the meantime BTOR will have been out and rerouted the line as part of a repair, then a sub sub sub contractor will tip up (the local council's handyman) with a chainsaw and get the job done, in the process he will also break the line again.......
We reported the problem to the council on the 3rd of September and nothing yet!
Re: Tree issue
21-09-2013 9:04 AM
you could if your able offer to lop the offending branch yourself but they will probably not allow it under there tree management plan ........there meant to use a specialist tree surgeon to prune them back but it depends where you live as to how on the ball the council are, if you reported the problem to your county council (there the ones with the money for it) they might do it within the year
