Telephone line not working
- Home Phone
- Re: Telephone line not working
30-01-2013 4:46 PM
Just had fibre optic b/b put in They changed the master socket in the house but my wife forget to mention we have got another fixed line phone and socket up stairs in the office just a extension really but this phone no longer works , is it a simple problem which I could fix or do I need to get a expert in
Message 1 of 6
(1,312 Views)
5 REPLIES 5
31-01-2013 7:50 AM
Had plus net fibre optic BB fitted last week when I wasn't in , the engineer changed the master socket and looked at the other sockets down stairs but my wife forget to mention the other fixed socket upstairs in the spare bedroom/office hence now the fixed line telephone up there now doesn't work is there anything I can do to put this right or do I need to get a engineer in???
Message 2 of 6
(555 Views)
31-01-2013 8:06 AM
Was the entire master socket replaced? The standard install of fitting an interstitial filter (the part which sits in between the back piece with the logo and the lower front piece with the socket) on the existing socket should not affect any extension wiring connected to it (save for a cable getting accidentally pulled out).
Does it not work at all, or does it simply not ring?
Message 3 of 6
(555 Views)
31-01-2013 1:39 PM
If it was completely replaced which sounds like it was the case, it would then need connecting up-to the new master socket. But as CX has just mentioned is it not working at all or is it just not ringing?
Message 4 of 6
(555 Views)
31-01-2013 1:49 PM
topics merged
Message 5 of 6
(555 Views)
31-01-2013 3:47 PM
The socket upstairs does not work at all no dial tone
Message 6 of 6
(555 Views)
- Home Phone
