Call Plan, Rental Saver & Caller ID
- Home Phone
- Call Plan, Rental Saver & Caller ID
25-01-2013 8:27 AM
(1) https://portal.plus.net/home-broadband/tariffs/
(2) https://portal.plus.net/home-broadband/
Why oh why isn't the request for line-rental-saver integrated into the order process?!
After initial enquiries, before placing my order, I was convinced I get to keep the *same* features as I currently had with BT and that included caller ID. Now I discover it's an "extra". In addition I'm fairly certain that this has been a standard feature provided by BT for some time to combat spam calls.
While I'm here I may as well point out that my "unlimited fibre BB + any-time plan" was discovered on Wednesday not to be correct (set to "essentials") and, I suspect as a result, my speeds are way below estimates. All this reported ~36hrs ago and still no response.
Re: Call Plan, Rental Saver & Caller ID
25-01-2013 10:05 AM
I've linked to the inclusive calls that are included in our call packages on our website, http://www.plus.net/home-broadband/package-guides/phone#inclusive-calls I hope that helps confirm that you get the 0870 and 0845 numbers included.
I can see that you've since added the line rental saver option, it's not something at the moment that is currently built into the order journey if you're a existing customer.
Regarding your speeds I've checked over your line and can see that your currently below your line estimate. I'd suggest running through the checks at http://faults.plus.net and let me know when you've done that and I'll get this picked up straight away.
Chris
25-01-2013 10:36 AM
Quote from: chrispurvey Regarding your speeds I've checked over your line and can see that your currently below your line estimate. I'd suggest running through the checks at http://faults.plus.net and let me know when you've done that and I'll get this picked up straight away.
I started the fault checker but then stop when, based on the current sync speeds, I checked and found I am not on the "unlimited" package that I signed up for. AFAIU the package dictates sync speed, ie, I can't get much greater than 16M because my sync-speed/profile is set to 20M... and I won't get anywhere near estimates until I'm put on the correct "unlimited" package. Correct?
25-01-2013 10:44 AM
The only ones where the package affects things are Fibre where there are two variants 40/10 and 80/20 and speeds of 20Mb are well below either package
ADSL has the same speeds regardless of the package
25-01-2013 10:47 AM
jim:quote
25-01-2013 11:00 AM
Quote The only ones where the package affects things are Fibre where there are two variants 40/10 and 80/20 and speeds of 20Mb are well below either package
25-01-2013 11:11 AM
Download speedachieved during the test was - 16.41 Mbps
For your connection, the acceptable range of speedsis 12 Mbps-21.04 Mbps .
Additional Information:
IP Profile for your line is - 21.04 Mbps
Upload speed achieved during the test was - 1.66Mbps
Upstream Rate IP profile on your line is - 2 Mbps
PS: It's always good to have someone else chip in. However my point was that an issue submitted via the formal route has not been addressed.
jim:quote
25-01-2013 11:15 AM
You're currently on Essentials, I'm guessing you wanting to be on Unlimited? Let me know and I'll get that changed over if you want. The difference will be usage and not speeds for you by switching.
The 21.04 Mbps profile you have got is because that's what your current speed is syncing around.
I'll get your ticket picked up too.
25-01-2013 1:32 PM
Quote from: chrispurvey Your line speed estimate is 36/Mb/s so if you're on essentials you should still be receiving that speed, if you can compete the faults checker then I'll take this further.
Done
Quote from: chrispurvey You're currently on Essentials, I'm guessing you wanting to be on Unlimited? Let me know and I'll get that changed over if you want. The difference will be usage and not speeds for you by switching.
Yes please, I signed up for "unlimited" not "essentials".
Quote from: chrispurvey The 21.04 Mbps profile you have got is because that's what your current speed is syncing around.
So it's a fault? I got the impression from other posts that limits may be applied by PN.
Quote from: chrispurvey I'll get your ticket picked up too.
Thanks.
25-01-2013 2:35 PM
You have a IP profile which BT set and we also apply one to your line, the one you have posted is the BT one.
You're also on unlimited too.
25-01-2013 3:43 PM
Quote from: chrispurvey I tried to call your mobile and landline, I need to arrange an engineer appointment. We have a slot for tomorrow 8am-1pm or 1pm-6pm if that is any good for you?
1pm to 6pm would be great, thanks. Sorry I missed your call, rung back but no answer. Please confirm if that slot is free.
Quote from: chrispurvey You have a IP profile which BT set and we also apply one to your line, the one you have posted is the BT one.
Where do a find the PN one?
Quote from: chrispurvey You're also on unlimited too.
Thanks!
25-01-2013 3:48 PM
25-01-2013 3:57 PM
25-01-2013 4:11 PM
The answer is that it should but until a delta report is received it is set to a default which in this case appears to be 37Mbps
25-01-2013 5:11 PM
Let us know how it goes.
- Home Phone
