Phone not ringing
Susan99
Phone not ringing
My landline has stopped ringing - it gives two little spurts of a ring tone then just dies. I can call out successfully and if I pick up when I hear the ringing the call is connected without any problems. Any ideas? (I've checked the sockets etc already.)
5 REPLIES 5
Gel
Aspiring Champion
Fixes: 29
Re: Phone not ringing
If you've multiple phones connected, try unplugging some, to see if that helps.
If you've added some lately, you may have gone over the maximum REN allowed
on your line.
198kHz
Fixes: 41
Likely to be a case of ring trip , usually caused by a dodgy joint in the external network.
It would be useful if you could establish whether the caller receives normal ring tone, or whether that also stops prematurely.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
RandallFlagg
Fixes: 75
Hi @Susan99
I agree with the above advice you've been given.
If you raise a phone fault here, we'll be happy to investigate this for you.
Best wishes
Dave
Susan99
Thank you all for your replies. I have raised a fault and it should be fixed by Monday.
RandallFlagg
Fixes: 75
Pleased to hear this, @Susan99
If you need any further support, just drop us a PM with your account details.
Best wishes
Dave
