Phone not ringing
FIXED- Subscribe to RSS Feed
- Home Phone
- Phone not ringing
10-12-2019 4:31 PM - edited 10-12-2019 4:32 PM
My landline has stopped ringing - it gives two little spurts of a ring tone then just dies. I can call out successfully and if I pick up when I hear the ringing the call is connected without any problems. Any ideas? (I've checked the sockets etc already.)
Fixed! Go to the fix.
Re: Phone not ringing
10-12-2019 5:27 PM
If you've multiple phones connected, try unplugging some, to see if that helps.
If you've added some lately, you may have gone over the maximum REN allowed
on your line.
10-12-2019 11:18 PM - edited 10-12-2019 11:20 PM
Likely to be a case of ring trip , usually caused by a dodgy joint in the external network.
It would be useful if you could establish whether the caller receives normal ring tone, or whether that also stops prematurely.
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
11-12-2019 2:47 PM
12-12-2019 10:35 AM
Thank you all for your replies. I have raised a fault and it should be fixed by Monday.
12-12-2019 11:25 AM
Pleased to hear this, @Susan99
If you need any further support, just drop us a PM with your account details.
Best wishes
Dave
