Phone line.dead but broadband working
- Home Phone
- Phone line.dead but broadband working
11-04-2018 8:55 PM
Re: Phone line.dead but broadband working
11-04-2018 9:08 PM
Have you reported a fault?
Your phone needs two wires to work, but broadband only one of them, although it is likely to be slower.
That said, electricity cuts don't normally affect the phone lines, are you using a corded or cordless phone?
12-04-2018 8:19 AM
12-04-2018 8:40 AM - edited 12-04-2018 8:41 AM
You might get lucky if a staff member sees your post.
In the meantime, have a look at the Help pages and click on the trouble-shooter link. Or try chat if/when it is available.
12-04-2018 8:43 AM
12-04-2018 9:00 AM
12-04-2018 9:14 AM
Welcome to the community forums @Laurawalker222
Our tests aren't finding a problem with your phone line.
Can you run through the troubleshooting steps here and here letting us know how it goes?
If you've still got no dial tone we'll need to book an engineer visit to further investigate.
12-04-2018 5:30 PM
If the user has no dial tone ... and the phone circuit test process finds no fault ... then this is potentially a crossed line case and the line being 'successfully' terminated elsewhere ... with the risk that calls not made by the user might be billed to the user.
Is there a means by which this can be noted on the account now please, so that if an issue arises later, there is a clear stake in the ground?
Thanks.
12-04-2018 5:36 PM
Coincidence of a fault like this with a power failure seems odd. My first inclination was that the power-outage damaged the DECT phone system, but you say that you have tried a corded phone (known to work?) in the (master?) socket?
If you are certain of the phone working, there is merit on you periodically ringing your own phone number to see if anyone answers it. There is some possibility that BTOR engineering work (or cable damage) has crossed your line with another and it is "terminating" elsewhere. That is one logical explanation for the line test finding no fault and you would be wise to see if this is the case.
I noted MASTER socket above as I have seen similar issues with internal cable failures - router on master socket is OK but the phone when used on an extension is dead.
19-04-2018 8:47 AM
19-04-2018 9:44 AM
Hi Laura,
Plusnet cannot set up an out-bound chat. Chat is always not available if approached from "Help & Support" - use he "Contact Us" route.
Alternatively use the phone fault on-line test / fault reporter - see link below.
19-04-2018 1:32 PM
From what I can see, we've since booked an engineer appointment.
I've also checked your itemised bill and I can't see any chargeable calls.
Can you let us know how the visit goes?
- Home Phone
