Phone line.dead but broadband working
Laurawalker222
Our electricity was off on Sunday and since it came. Back on Internet working but no dial tone on phone. If you phone our landline it rings but doesn't ring in the house and you can't phone out.
11 REPLIES 11
Mustrum
Fixes: 81
Re: Phone line.dead but broadband working
Have you reported a fault?
Your phone needs two wires to work, but broadband only one of them, although it is likely to be slower.
That said, electricity cuts don't normally affect the phone lines, are you using a corded or cordless phone?
Laurawalker222
We have cordless phones but I tried with a corded phone and the same issue. Can't report as we have no phone and mobiles have no signal so thought I would try this
Mustrum
Fixes: 81
You might get lucky if a staff member sees your post.
In the meantime, have a look at the Help pages and click on the trouble-shooter link. Or try chat if/when it is available.
Laurawalker222
Have tried that and the online chat is never available.....
Fixes: 202
Chat availability - see https://community.plus.net/t5/Plusnet-Feedback/Chat-service-availability/td-p/1510365/jump-to/first-...
Fixes: 1,630
Welcome to the community forums @Laurawalker222
Our tests aren't finding a problem with your phone line.
Can you run through the troubleshooting steps here and here letting us know how it goes?
If you've still got no dial tone we'll need to book an engineer visit to further investigate.
Fixes: 202
@Gandalf,
If the user has no dial tone ... and the phone circuit test process finds no fault ... then this is potentially a crossed line case and the line being 'successfully' terminated elsewhere ... with the risk that calls not made by the user might be billed to the user.
Is there a means by which this can be noted on the account now please, so that if an issue arises later, there is a clear stake in the ground?
Thanks.
Fixes: 202
@Laurawalker222,
Coincidence of a fault like this with a power failure seems odd.  My first inclination was that the power-outage damaged the DECT phone system, but you say that you have tried a corded phone (known to work?) in the (master?) socket?
If you are certain of the phone working, there is merit on you periodically ringing your own phone number to see if anyone answers it.  There is some possibility that BTOR engineering work (or cable damage) has crossed your line with another and it is "terminating" elsewhere.  That is one logical explanation for the line test finding no fault and you would be wise to see if this is the case.
I noted MASTER socket above as I have seen similar issues with internal cable failures - router on master socket is OK but the phone when used on an extension is dead.
Laurawalker222
Still no phone line almost two weeks on and my husband has tried to phone and report from work but noone will speak to him. Bc account in my name but I have no way of phoning. Can anyone from plus net either set up an online chat as it tells me it's unavailable or email me regarding this issue
Fixes: 202
Hi Laura,
Plusnet cannot set up an out-bound chat.  Chat is always not available if approached from "Help & Support" - use he "Contact Us" route.
Alternatively use the phone fault on-line test / fault reporter - see link below.
Fixes: 1,630
@Laurawalker222
From what I can see, we've since booked an engineer appointment.
I've also checked your itemised bill and I can't see any chargeable calls.
Can you let us know how the visit goes?
