People say ots a bad line on outgoing call(s)
- Home Phone
- People say ots a bad line on outgoing call(s)
Re: People say ots a bad line on outgoing call(s)
03-04-2014 5:18 AM
We were discussing my bill & the call just dropped, out of the blue
I have completed a 17070
1. Ringback (Phone rung back)
2. Quietline test (Noise on line)
03-04-2014 9:08 AM
Just to be thorough, have you:
- Tried an alternate handset?
- Connected your phone directly into the Test Socket with no other equipment connected to your telephone sockets?
If so, do you still get noise on the 17070 quiet line test?
03-04-2014 3:26 PM
1. Corded handset (Noise on line)
2. Corded handset in Test socket (Noise on line)
3. Corded handset in test socket with Recorder to record the noise on the line
There was nothing on the logs that I could see for the time the call dropped
That said
There was another Line drop @ 09:05AM
Quote Error Apr 3 09:07:47 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 141.136.51.48 Dst ip: [IP ADDRESS REMOVED] Type: Destination Unreachable Code: Port Unreacheable
Info Apr 3 09:07:02 CONFIGURATION saved by TR69
Info Apr 3 09:06:47 FIREWALL event (1 of 1): deleted rules
Warning Apr 3 09:06:47 PPP link up (Internet) [IP ADDRESS REMOVED]
Info Apr 3 09:06:46 PPP CHAP Chap receive success : authentication ok
Info Apr 3 09:06:44 PPP CHAP Receive challenge (rhost = PTW-AG03)
Info Apr 3 09:06:41 PPP CHAP Receive challenge (rhost = bras-red9.cf-c)
Info Apr 3 09:06:35 xDSL linestate up (ITU-T G.992.5; downstream: 9721 kbit/s, upstream: 708 kbit/s; output Power Down: 20.9 dBm, Up: 12.2 dBm; line Attenuation Down: 48.0 dB, Up: 27.3 dB; snr Margin Down: 3.5 dB, Up: 5.0 dB)
Warning Apr 3 09:06:19 PPP link down (Internet)[IP ADDRESS REMOVED]
Info Apr 3 09:06:07 xDSL linestate down
Info Apr 3 09:05:35 FIREWALL event (1 of 1): modified rules
Info Apr 3 09:05:35 FIREWALL event (1 of 1): created rules
Info Apr 3 09:05:35 xDSL linestate down
Error Apr 3 08:53:04 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 222.235.204.64 Dst ip: [IP ADDRESS REMOVED] Type: Destination Unreachable Code: Port Unreacheable
See also Post#264 for last reported outage although there was 1 yesterday morning approx the same time
Quote 165.60 Dst ip: [IP ADDRESS REMOVED] Type: Destination Unreachable Code: Port Unreacheab
e
132> Apr 2 09:04:08 PPP link down (Internet)[IP ADDRESS REMOVED]
85> Apr 2 09:04:09 FIREWALL event (1 of 1): created rules
85> Apr 2 09:04:09 FIREWALL event (1 of 1): modified rules
39> Apr 2 09:04:22 PPP CHAP Receive challenge (rhost = bras-red9.cf-c)
39> Apr 2 09:04:22 PPP CHAP Receive challenge (rhost = PCL-AG06)
38> Apr 2 09:04:23 PPP CHAP Chap receive success : authentication ok
132> Apr 2 09:04:23 PPP link up (Internet) [IP ADDRESS REMOVED]
85> Apr 2 09:04:24 FIREWALL event (1 of 1): deleted rules
14> Apr 2 09:04:39 CONFIGURATION saved by TR69
81> Apr 2 09:10:27 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 75.48
4.80 Dst ip: [IP ADDRESS REMOVED] Type: Destination Unreachable Code: Port Unreacheabl
Then there was the deliberate connection drop at 14:44PM when I completed the quiet line test Via the Test socket
looking at the logs
Syslog (noting to indicate why the drop occurred)
DNS Server Trace (nothing to indicate why the drop occurred)
Nslookup Same results as Post #263
Edit:
Stray [IP ADDRESS REMOVED]
03-04-2014 4:02 PM
03-04-2014 4:29 PM
Yes the noise did disappear, hence why I cancelled the engineer's appointment on the 18th, as I felt it would of been a waste of his' / her time if they was unable to detect it at that time.
03-04-2014 4:54 PM
So moving onto the drops you've noticed - I wonder, do the drops occur on your broadband when connected into the Test Socket?
I know there's a few drops as highlighted above, but it'd be good to have your connection in there for a few days if possible?
03-04-2014 5:05 PM
Will update when I have completed that task (sometime later this evening I hope)
03-04-2014 5:11 PM
03-04-2014 10:08 PM
Another drop this evening
Quote Error Apr 3 19:53:13 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 202.118.201.7 Dst ip: [IP ADDRESS REMOVED] Type: Destination Unreachable Code: Port Unreacheable
Info Apr 3 19:47:44 LOGIN User admin logged in on [HTTP] (from 192.168.1.64)
Info Apr 3 19:47:35 CONFIGURATION saved by TR69
Info Apr 3 19:47:20 FIREWALL event (1 of 1): deleted rules
Warning Apr 3 19:47:19 PPP link up (Internet) [IP ADDRESS REMOVED]
Info Apr 3 19:47:19 PPP CHAP Chap receive success : authentication ok
Info Apr 3 19:47:18 PPP CHAP Receive challenge (rhost = PCL-AG01)
Info Apr 3 19:47:17 PPP CHAP Receive challenge (rhost = bras-red9.cf-c)
Info Apr 3 19:47:04 FIREWALL event (1 of 1): modified rules
Info Apr 3 19:47:04 FIREWALL event (1 of 1): created rules
Warning Apr 3 19:47:04 PPP link down (Internet) [IP ADDRESS REMOVED]
Info Apr 3 19:32:29 LOGIN wireless station [xx:xx:xx:xx:xx:xx] can't get authorized.
Info Apr 3 17:49:08 LOGIN User admin logged in on [HTTP] (from 192.168.1.64)
Info Apr 3 17:47:49 LOGIN User admin logged in on [HTTP] (from 192.168.1.64)
Info Apr 3 17:41:01 SNTP Synchronised again to server: 212.159.13.49
Error Apr 3 17:35:14 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 14.45.63.195 Dst ip: [IP ADDRESS REMOVED] Type: Destination Unreachable Code: Port Unreacheable
Syslog / Config trace are not showing anything new
04-04-2014 12:11 AM
Quote Info Apr 4 00:07:07
04-04-2014 4:01 PM
Quote Error Apr 4 15:33:29 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 75.145.229.89 Dst ip: [IP ADDRESS REMOVED] Type: Destination Unreachable Code: Host Unreacheable
Info Apr 4 15:32:10 CONFIGURATION saved by TR69
Info Apr 4 15:31:55 FIREWALL event (1 of 1): deleted rules
Warning Apr 4 15:31:54 PPP link up (Internet) [IP ADDRESS REMOVED]
Info Apr 4 15:31:54 PPP CHAP Chap receive success : authentication ok
Info Apr 4 15:31:53 PPP CHAP Receive challenge (rhost = PTN-AG01)
Info Apr 4 15:31:53 PPP CHAP Receive challenge (rhost = bras-red9.cf-c)
Info Apr 4 15:31:33 FIREWALL event (1 of 1): modified rules
Info Apr 4 15:31:33 FIREWALL event (1 of 1): created rules
Warning Apr 4 15:31:33 PPP link down (Internet) [IP ADDRESS REMOVED]
Error Apr 4 15:08:21 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 1.173.242.181 Dst ip: [IP ADDRESS REMOVED] Type: Destination Unreachable Code: Port Unreacheable
Error Apr 4 14:50:41 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 200.35.32.34 Dst ip: [IP ADDRESS REMOVED] Type: Time Exceeded Code: Time to Live exceeded in Transit
Is there anything showing your end, as to why this is happening & gradually getting worse ?? ?? ?
07-04-2014 4:00 PM
Quote <81> Apr 6 18:37:18 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 76.191.33.34 Dst ip: [IP ADDRESS REMOVED] Type: Destination Unreachable Code: Port Unreacheable
<102> Apr 6 18:47:10 SNTP Synchronised again to server: 212.159.13.50
<102> Apr 7 00:47:09 SNTP Synchronised to server: 212.159.6.9
<132> Apr 7 06:46:09 PPP link down (Internet) [IP ADDRESS REMOVED]
<85> Apr 7 06:46:09 FIREWALL event (1 of 26): created rules
<85> Apr 7 06:46:09 FIREWALL event (1 of 16): modified rules
<39> Apr 7 06:46:22 PPP CHAP Receive challenge (rhost = bras-red9.cf-c)
<39> Apr 7 06:46:23 PPP CHAP Receive challenge (rhost = PTW-AG01)
<38> Apr 7 06:46:24 PPP CHAP Chap receive success : authentication ok
<132> Apr 7 06:46:25 PPP link up (Internet) [IP ADDRESS REMOVED]
<85> Apr 7 06:46:25 FIREWALL event (1 of 1): deleted rules
<14> Apr 7 06:46:40 CONFIGURATION saved by TR69
<102> Apr 7 06:47:09 SNTP Synchronised again to server: 212.159.6.9
<81> Apr 7 06:54:55 FIREWALL icmp check (1 of 1): Protocol: ICMP Src ip: 110.172.53.81 Dst ip: [IP ADDRESS REMOVED] Type: Time Exceeded Code: Time to Live exceeded
in Transit
I will send the logs via email to Matt as I have done before, although I can not see what could of caused it
07-04-2014 4:03 PM
07-04-2014 4:21 PM
Matt Turner
07-04-2014 4:48 PM
- Home Phone
