Overhead Cable Issue
itlity
Hi Community,
Looking for some advice re. the way to handle the situation.
Our phone overhead cable from the pole to our house is entangled in trees. The trees are just outside the fence of our property -not falling into our responsibility re. trimming though we do some. After the end-of-2021 storms one of tress started to push down on the overhead cable, over the last week-end it got worse: the cable is no longer fixed on the house wall, just flying loose at 2 m high or about.
I still have my landline -and Internet- working OK but I suspect the next serious storm will see the tree falling and bringing down the cable. I don't think the max sag would be enough to have the cable to the level of a coach/bus roof, but as the last pole is across the road that worries me.
I dropped a text message on PlusNet support line to investigate a fault which does not exist yet, that led to nothing as expected.
What's the process to have someone from OpenReach coming over to survey the issue and arrange the tree trimming?
5 REPLIES 5
Fixes: 118
Re: Overhead Cable Issue
@itlity
I believe you can report it direct to OpenReach yourself.
https://www.openreach.com/help-and-support/damage-health-and-safety
itlity
Many thanks for the reply and link.
Patrice
Fixes: 1,665
Hi Patrice,
Let me know how that goes as I can raise a "Damage Report Overhead" our side if Openreach can't help you directly.
itlity
Hi Gandalf,
Many thanks for the offer.
I have now a job reference number and they're supposed to come over within the next 48 hours. I guess they'll only make note they need their subcontractor to trim the trees before fixing the cable issue. But at least there is a momentum,
Will update if there is nothing happening or when it's fixed.
Fixes: 1,665
No problem and sounds like a plan!
