No home phone - landline number?
DKN7
Hi all,
Is there anywhere on my plusnet account that tells me what my landline number is? I can't see it under My Account.
Thanks,
Daren
7 REPLIES 7
Fixes: 139
Re: No home phone - landline number?
@DKN7
Login into the members centre https://www.plus.net/member-centre/home select Phone, this takes you to the Phone Control panel
HTH
DKN7
Thanks for the reply.
No option of a phone control panel. I get my landline as part of the broadband package, does that affect where I can see the landline number?
Fixes: 139
My landline is part of my package, I see this in the members centre.
Just checked and you can get to the Home Phone Control Panel via Manage Account.
HTH
Dan
Fixes: 1,652
Hi Daren,
Does the phone tab show your landline number?
DKN7
Thanks - i can see it now. I swear it wasn’t there before!
RobPN
Fixes: 13
@DKN7
If you're asking because you don't know your number, call 17070 (free) using a phone attached to your line and listen to the number read out to you.
Fixes: 139
@RobPN
The title suggests he doesn't have a landline phone, so the members centre would be the obvious way to check. Perhaps he can borrow a landline phone.
It's a bit of a concern he can't find it in the members centre.
